Hi all,
After my 406 hdi recently gave up on me it has been sat on my drive for a couple of months waiting to go to that big old scrap yard in the sky. Last week i decided i couldn't bear to part with the old girl so i went about remediating the fault i had with the fuel pressure regulator ( removed and cleaned it) All went well with that and engine is running beautifully. However upon taking it for a long test drive i have noticed a few other issues which i didnt notice before.
1. The gear lever and car is shaking quite badly on acceleration but is accelerating smoothly.
2. There is an awful smell of fish and the windscreen steams up really easily.
3. The fans have stopped working
Anyone have any suggestions as to whats going on?
2001 406 hdi 90
spider
- x 77
2. Sounds like your heater matrix is leaking
3. Could be related to (2) if you meant the heater fan, if you mean the radiator fans check fuses and the three relays fitted under the grille (caution: disconnect battery before going near as they are permanently live, fingers + fans = not good)
Andy.
kaostheory
spider
- x 77
There are "treatments" you can pour into your coolant system to stem the flow (as it were) although I've never used any myself, so cannot really say how well they will work.
Have a quick look in the Citroen forum as I recall heater matrix problems have been discussed recently (although someone will probably reply to this topic soon anyway)
Andy.
kaostheory
kaostheory
spider
- x 77
kaostheory
Bit of bad explaining and wrong words used there. I mean there is no loss in acceleration/power but the whole car shakes quite violently.
My uneducated guess would be an engine mount or support of some kind but dont know how to check this at the moment.
I have just drained the coolant and flushed through a few times with tap water and refilled with 50/50 coolant/distilled water and forte stop leak. See where that gets me.
The fans(heater) have a wire coming from the unit and is melted so will need to replace that at some point.
Apart from that a good wash and hoover is in order!!!
