Rasping sound.....deep bass resonation
vince
x 13
Unread post by vince »
Ive just been reminded of this on mine whilst reading the Activa register thread.....
1995 TD Xantia.....
At 1500rpm when driving and the revs kept constant i get a continuous rasping sound as if an exhaust bracket is vibrating or something....also when idling the engine omits a very deep bass resonation which is worse when you open the sunroof or windows but strangely if you are stood outside the car you cant hear it at all...
Someone mentioned manifold? The bass thing definately started just after i had the headgasket done..
Thoughts people? Its one of the things i really want to nail as its annoying more than anything else...performance is otherwise the same.
x 5674
Your car is possessed, you need to call Ghostbusters or an exorcist :evil:
vince
x 13
Ha ha :lol: I wish it was that easy...phone a priest and everything would be fixed :P
No ideas anyone?
XantiaMan
x 18
Unread post by XantiaMan »
Sure its not a split inlet pipe? The pipe from air filter box to turbo top pipe is a common failure, and could cause excess induction noise but no affect on performance, apart from drawing in dirty air... Its possible it was disturbed and now split.
x 94
Unread post by citronut »
if the aux belt auto tenssioner is over adjusted by to much tenssion it can cause a clattering noise against the cam belt cover, i think this is more at certain revs,
regards malcolm
vince
x 13
Thanks for the ideas guys but it is definately a metal droning noise...like as if you had a loose baffle in a silencer or something. The silencer is new ish though....Could still be my new rear brake backplates but the bass noise i think is definately located up front somewhere....
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi Vince
Did you recently renew your handbrake cables :?: :?:
If so could the heat shield have become detatched and vibrating
Just a thought probably miles off target :)
Colin
x 94
Vince wrote
"The silencer is new ish though"
not one of them there cheap GSF whooops i mean ECS exhaust box's is it
regards malcolm
Nutcase
Unread post by Nutcase »
Might be worth checking the undertray - if a fixing is missing or it is split/damaged you could get similar noise when moving.
I also wonder if you could get noise from the EGR valve if the moving internals are damaged in any way (as I gather it wouldn't be noticeable performace wise?). I would guess this should be repeatedable when stationery though.
Happy hunting
Greg
2001 Xsara HDI 110 150,000 & counting!
vince
x 13
regards malcolm
Ha ha no its not Malcolm....i did fit one of those but took it off after a week or so....it sounded terrible...you get what you pay for i guess :P
I fitted the dearer one then :wink:
