Spheres and stuff
davewithington
Spheres and stuff
Unread post by davewithington »
Just bit the bullet and ordered a set of six spheres and Hydraflush from Pleiades. I'm going for normal VSX spheres, as I have this mission to restore the suspension to what it should be, with full Hydractive action, so new spheres, flush out, then start to change/ repair from a known base - I chaged the accumulator sphere before Christmas.
Should be a photo or two of the beast if I've done the posting properly - I've always had problems before.
[/img]
aerodynamica
x 215
Unread post by aerodynamica »
Nice! Mk1 VSX - my fave Xantia
Graeme M
arkweld
Unread post by arkweld »
Yeah , i had a VSX in white , really liked the clean interior dash and open feel with the sunroof , I got rid of it because the brake warning light stayed on , this was before a search and solve way of doing things was applied .
Do you think rejuvenated original spheres (unless there completely skuzzy)is a better way to go than new aftermarket ?
aerodynamica
x 215
arkweld wrote:Yeah , i had a VSX in white , really liked the clean interior dash and open feel with the sunroof , I got rid of it because the brake warning light stayed on , this was before a search and solve way of doing things was applied .
Recharged spheres? well, increasingly it's harder to find places that recharge them but if you have genuine Citroen spheres then recharging them is like having a new set of Cit items but for mega cheap. Of course, you need to take care that it's done correctly (cleaning the area around the filler keenly) and to the right pressure for fronts or rears for the particular model in question.
I've had nothing but good experience with recharged spheres on my CX and former BX - 3 years after the CX fronts were done they are still plush.
Graeme M
davewithington
When my land Rover died quite spectacularly last November - lots of banging noises and smoke - I needed something quickly, and this car presented itself. Liked the look, the mileage (105,000) and the price (£350) so I bought it, fetched it from Wigan the same evening. After some thought I'm going the original route. make it work properly, keep it forever, or until I don't drive anymore, would could be 10 to 20 years.
I'll probably need a replacement accumulator, as the present one emits a noise like, sort of a cross between a rattlesnake and throat clearing, so see what happens when the Hydraflush has been in a few miles.
x 8397
davewithington wrote: I'll probably need a replacement accumulator, as the present one emits a noise like, sort of a cross between a rattlesnake and throat clearing,
How often does it make this noise Dave?
Some pumps make this noise when they're activly pumping and it goes with the regulator tick.
Regulator cuts in and the pump makes a noise like a little machine-gun for a second or two until the regulator cuts out. Provided the noise is there only for a second or two and spaced at least 30s apart at idle, no worries..
Any less certainly suggests the accumulator needs replacement.
Did you get just the corners and centres? What about the anti-sink sphere?
davewithington
Unfortunately Citrojim it's about every 20 seconds, so I'll investigate further after spheres. Certainly could do with them on the back so I'll change the lot, know where I am then.
There seems to be an issue with fluid pressure, the back end sits down almost as soon as the engine is switched off, but things could be a bit sticky in there. All symptoms are worse in freezing weather, so I reckon the fluid's a bit old and thick as well.
vince
x 13
Unread post by vince »
Hi Dave thats one good looking Xantia you have there.....I always liked white Xantias and series 1's with the chevrons on the bonnet :wink:
aerodynamica
x 215
Jim! this Xant ain't got no anti sink :wink:
Also, this being a Mark 1 Xantia means it will use an FDV valve in addition to the accumulator and pressure regulator. The FDV emits a very audible SHHHHHH noise at times such as when the engine is running and you press the brakes. So this can be mistaken for a fault at times.
Graeme M
aerodynamica
x 215
Also Dave, I know you're hanging onto it but if you ever tire of this Xant give me a bell! I'd love to own one of the old Mk1s again!
Graeme M
davewithington
Had the spheres and Hydraflush yesterday, and had a few minutes spare this afternoon so thought I'd see how far I got on the sphere change. Did all three rears in about 30 minutes, the two fronts were a doddlwe, but the third sphere, mounted behind the radiator..... that it going to be a pain, I just know it. I can get the removal tool (Pleiades own) onto the sphere OK, but the mounting bracket for the valve is a bit floppy, so I can't get enough welly on the tool to undo the sphere. Looks like I'll have to remove the valve to change the sphere unless I can just sprag the bracket enough to get that initial loosening.
Amazing result though. Haven't actually dribven it yet, but the back end now stays up, not flumping down really quickly, so I'm hoping the beast will rise from his slumbers quicker.
Next weekend - fluid change
x 8397
I know your problem well Dave as I had the same issue on my Activa project. The centre Hydractive was both flat and had never been off in the life of the car.
A floppy bracket means most of the work you put into shifting the sphere goes into flexing the bracket.
There is a simple answer. A big cold chisel and punch. Raise a ridge on the weld around the sphere using a cold chisel and then use a long punch against the ridge and large club hammer to shock the sphere loose.
It really does work like a charm...
davewithington
I will try that Jim - I've got a lovely long cold chisel on the shelf.
x 8397
Just mind the rad Dave :twisted:
davewithington
It was the presence of the rad which stopped me getting creative with my crowbar
