Snatchy accelerator on my Xantia
hirsty
- x 9
My xantia has started jerking when backing off/ accelerating. Is this likeley to be a soggy engine mount or a throttle cable issue? At all other times it runs smoothly.
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
- x 8058
Is it just a jerk or can you feel a misfire?
A jerk is indicative of engine mounts, especially the lower donut mount. These can go soft through oil contamination.
You can tell how good it is by trying to rock the engine by grabbing hold of the cam cover (or other stout item at the top of the engine) and trying to rock it to and fro. It should be hard to do this...
Another oft cause is a broken bush in the top mount torque reaction link if your engine has one. This is a link that goes from the top RH engine mount to the inner wing and has a rubber donut bush at each end. The smaller of these two break and cause the engine to rock.
spider
- x 77
hirsty
- x 9
