My fuel gauge just started reading over full. This was preceded by the radio cutting out and the Service light coming on. Didn't notice any immobiliser messages, which is what I normally get with those symptoms.
I've pulled the connector off the sender - it looks clean and healthy. The gauge drops to empty with the igniton off.
Does it sound like a new sender unit is needed? Which is the sender wire and which is power?
Any special precautions before I try to do this?
C5 HDi fuel gauge
- x 1938
The fuel gauge isn't fed directly but by the ECU. The first thing I would try would be disconnect the battery for a few minutes.
zilly
zilly
Well the gauge is now working, in that it is showing a level lower than over full.
What I did find was that the trip computer and oodmeter, both reset when I filled up 100 miles ago, were reading about 15 miles different. Looks like the trip computer stopped counting miles when the fault occurred this morning, so it's likely it is an ECU fault rather than the fuel sender.
