C5 estate roof rails and dog guard
Julz
Unread post by Julz »
I've just bought a 2001 C5 LX estate, without roof rails running the length of the car.
I see Citroen sell the rails as an accessory for about £220 fitted, but was wondering if anyone knows how easy they are to fit yourself if I could get some from the breakers. I noticed there are 3 holes in the gutter which I presume is where they fit, that seem to have a sprung plate covering them but I'm not sure what is behind this. Any ideas anyone?
Also did Citroen ever make a dog guard for the estate, there website only seems to show one for the hatchback?
zilly
Unread post by zilly »
Hi yes Citroen make a dog guard - I have one in my car. It hangs in hooks behind plastic covers at the top and slots between the seat and load cover at the bottom.
Julz
zilly wrote:Hi yes Citroen make a dog guard - I have one in my car. It hangs in hooks behind plastic covers at the top and slots between the seat and load cover at the bottom.
thanks for that, I'll check with the dealer then :)
zilly
About £70 I when I got mine a couple of years ago.
x 1938
Unread post by Paul-R »
Is that different to the luggage guard then? The luggage guard retracts into a cylindrical tube attached to the back of one of the seats and would struggle to keep a determined Pekinese in my opinion.
zilly
Yes it's a big black steel mesh affair that closes off the gaps left at the sides by the luggage guard. Good piece of kit IMO - much better than the aftermarket ones I've seen.
Julz
on a similar theme, does anyone know if you can get a dog guard for the tailgate window, so that I can leave the window open when the dogs are in the back? (once I've managed to work out why my window won't open!)
And I've not had any response to my original question regarding the roof rails :(
Citroenmad
x 110
Unread post by Citroenmad »
I would think the rails are fairly easy to fit yourself. Its only the LX estate which miesses out on the roof rails, so you should be able to source some quite easily.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
cachaciero
x 9
Unread post by cachaciero »
IMHO the estate looks a lot better without the rails.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Citroenmad
x 110
I like the roof rails, especially on dark coloured C5 estates, looks quite classy having silver bars.
03 Seat Arosa 1.0S
john alexander
Unread post by john alexander »
Hi there is a very good posting on here about how to fix the back window, unfortunatly I don't know how to find it . I have used it and it works but I changed it slightly in that I attached the wire to the window with superglue and as we all know when it dries it leaves a white residue, this was painted over with matt black model paint. this method is neater than the sticky tape . John
