307 XT 2005 - aircon. supplies hot air
Post your Cit/Peu/Ren air conditioning queries or advice.
wonderd
Unread post by wonderd »
there is hot air coming out the vents when I turn the aircon. on.
In the engine compartment the aircon. pipes are freezing cold.
What could be the problem?
Elad.
Xantia 2.0L 16V manual trans. 96
Xantia 1.9L TD 99
Xaccers
x 185
Unread post by Xaccers »
you've got the temperature control set to hot?
a/c's purpose is to dry air, cooling is a side effect we like.
give it hot air and it will cool it but not enough to make it cold unless you have super powerful a/c
DIY sphere tool
wonderd
The temp is set to 17C, there is warm air coming out of there, it's not supposed to.
Xantia 1.9L TD 99
Xaccers
x 185
With aircon off do you get hot or cold air?
DIY sphere tool
wonderd
Hot usually.
Xantia 1.9L TD 99
Clogzz
x 40
Unread post by Clogzz »
2002 C5 2.0i AL4 239,000 km 76372389
wonderd
For some strange reason it is working good today, cold air is coming out the vents..
I have no idea what happened..
Xantia 1.9L TD 99
Xaccers
x 185
As Cloggz pointed to, probably a sticky heater flap
DIY sphere tool
