Hi all,
I've started a thread on the 406 Owners Club forum that has turned into a bit of a monster so thought it might be interesting to see how it rolled here.
Has anyone added 2 stroke oil to their fuel in the past and if so can you elaborate as to how it effected the performance of your car if at all?
At this point I have just started adding this to my fuel in my old bus and so far the results have been only beneficial with reduced smoke under load and a quieter (less rattly sounding) engine.
Any input from this?
Cheers
Steve
2 Stroke oil in diesel
98 406 Estate LX 2.1td in white (Anyone call Ghostbusters?)
97 Xantia SX 2.1td (Chipped and happy at 130mph) Deceased after agricultural incident (crashed into field).
1981 Mini HL (Just happy to be around)
2 stroke oil binds into the diesel in some sort of molecular way, i forget how exactly, but its beneficial and i have only ever seen reduced emissions each mot time and a quieter engine,
2 stroke oil is designed to be burnt in an engine whereas 4 stroke oil isnt which is why you will get more smoke with all oils other than 2 stroke when its added into the fuel
2000 miles since I started adding the oil and the car is definitely less smoky.
Mot in 2 months so will compare emissions results to last years for a definitive answer.
All good so far though.
If anything too much, about 500ml to a tank.
It wont do the motor any harm I just can be bothered with the mess of measuring it any closer and comes in a handy two dose bottle!
Thats exactly how much i use too !, half a litre per full fillup, that puts the mix ratio at about 140:1 which i think it about perfect when you consider that 2 stroke engines use anything from 50:1 to 100:1 usually, and you are only using the oil to 'top up' the diesels lubricity really, so it doesnt need as much as a 2 stroke would
