C3 Tyre Pressures
angrymutant
C3 Tyre Pressures
Unread post by angrymutant »
Greetings all, new member and first time poster here - apologies if I'm trading on toes or disregarding protocols, but I will learn!
Quick question: in the absence of the sticker on the passenger door of my 2004 C3 Desire, can anyone please help by telling me the correct tyre pressures?
Thanks in advance.
Citroenmad
x 110
Unread post by Citroenmad »
Welcome to the FCF :)
It might be in your handbook? Though it should have been on a sticker in your drivers door.
If you stick your reg number into the kwikfit website, it tells you what pressures you need. Make sure you check that it gives your tyre size. I usually find they are correct.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
angrymutant
Ah, but that it were so simple...
Handbook makes repeated mention of the necessity to maintain the correct tyre pressures, but never gets to tell me what those pressures are. It does say that the pressures are on a label on the door pillsr - but it ain't there...
Thanks for the tip re the KwikFit site. After being well and truly done over by them many years ago, they are the last place I'd trade with, but I'm not averse to using their information for free. However, it gives pressures for 185/65 15 tyres - my car has 165/70 14 inch ones. :(
Having a look at Michelin's site, I got pressures (for the correct tyre size) of 30 psi front and 33 psi rear for normal running, so I'm trying them at that. Feels ok so far.
Thanks for your help.
