405 drivers door difficult to open
bumperman
Unread post by bumperman »
Drivers door can only be opened from inside car with a hefty shove from my elbow? Seems that both inner and outer door handles are sort of jammed and don't want to release door(although inner handle will just about work with the elbow trick!)
Anyone got any ideas before I dismantle the door?
This fault happened after a 3 month period off the road, and I suspect the inner lock mechanism is jammed.
Bumperman
93 Peugeot 405 STDT ser 2 Estate manual Alhambra Red
89 Peugeot 505 GTi Estate manual Winchester Grey
87 Peugeot 505 GTi Estate manual Winchester Grey
96 Xantia td SX Estate RP6910 manual Quartz(silver)
r.welfare
Unread post by r.welfare »
My offside rear door suffers in the same way. The striker plate mounted on the door pillar can be loosened with a Torx driver and moved around a bit (up, down, in and out) which may help.
'93 405 Hunter TD estate
