help in using lexia3 ver 45 software
citrokid
Unread post by citrokid »
can anyone offer help in using lexia software version 45. recently bought from china, have hooked up to C5 2005, can see faults logs
how do you set/reset the service light? etc
x 1053
Re: help in using lexia3 ver 45 software
Unread post by wheeler »
citrokid wrote: how do you set/reset the service light? etc
You use the button on the instrument panel & the ignition key, no need for a lexia. It even tells you how to do it in the handbook.
colinxm
Unread post by colinxm »
Hi Gents, can any of you confirm that these chinese Lexias can programme (code) new, replacement components on multiplexed vehicles, specifically my wife's 2004 pug 307 1.6 petrol ? I'd buy one but don't want to waste my money if it can't do this...
Cheers Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
x 1938
Unread post by Paul-R »
AFAIK the Lexia software won't do it as it's dedicated to Citroens. Even though the electronics and cables are the same I don't see how it can work as the options in the car choice menu are only Citroen models.
TopDonkey
Unread post by TopDonkey »
If you buy an Actia interface, you can use it for Peugeot planet (peugeots) or Lexia (citroens)
the Actia is the hardware you need, the Lexia and Peugeot Planet are just bits of software
x 1938
Planete!... That's the name I couldn't remember. It's the equivalent software for the Peugeot to the Citoen's Lexia.
colinxm
Thanks Gents, I'll look into Actia and planete then :)
Colin.P
2004 Pug 307 SW
1998 Ford Puma
1979 Triumph TR7
