Calling HA experts
Stempy
Calling HA experts
Unread post by Stempy »
Went to have a look at a Xantia estate today with a view to purchase. It's in good nick, 80k miles FSH and currently on ebay at £1045 which is really at the upper end of what I'd want to pay. It has a years MOT but with advisories so will need 4 new tyres and a new back box before long. Also aircon doesn't function so will at least need a regas.
Anyway back to the question at hand, I noticed when testing the suspension that the pressure regulator ticked about every 2 seconds when on the high setting only, was fine on normal setting. Could this be the pump going home?
Lexia ponce
spliffy
Unread post by spliffy »
sounds very expensive to me i wouldnt exspect to pay more than £500 as for the air con you will be very lucky if it needs re gassing mine went on my estate, mine needed a £180 pipe and an £130 condensor ( the rad at the front ) yours probably will need a condensor at least then re gassing which is about £45 good luck mate
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
DickieG
Monaco's youngest playboy
x 38
Re: Calling HA experts
Unread post by DickieG »
Stempy wrote:Anyway back to the question at hand, I noticed when testing the suspension that the pressure regulator ticked about every 2 seconds when on the high setting only, was fine on normal setting. Could this be the pump going home?
The regulator does click in much quicker when on high, not sure about 2 seconds though, have you compared it with your V6?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8089
What was the tick rates on low and normal Stempy? Also, pull the HA fuse (F8) to check to see if the tick rate is the same when hard mode is forced.
If the tick rate is considerably longer in hard mode, the electrovalves are leaky.
Stempy
The V6 is about every 20 seconds on high.
I do think it's a bit over priced, it started at £850 but has started to get silly, especially as it's gonna need a bit of money spent. I'm after an auto estate and this one is only just down the road though. Have a look.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
I don't think the bloke would take kindly to me pulling fuses. Anyway, I've almost convinced myself to give it a wide berth for now.
Lexia ponce
DickieG
x 38
That Xantia is an SX so won't have Hydractive.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8089
Stempy, that's a very profound statement in your signature :D
Very true though!
Stempy
DickieG wrote:That Xantia is an SX so won't have Hydractive.
Actually, that's a very good point. :oops:
Lexia ponce
