Xsara engine-code question
VertVega
x 13
Unread post by VertVega »
Did you try to check from the chassis number?
In 1.4 Xsara it should be KFW (TU3JP) or KFX (TU3JP).
In my MK2 Xantia, engine code RFV (XU10J4R) can be interpreted from chasis number like this:
VF7**************[VIN obfuscated, can be read by forum staff]...
V = Europe
F = France
7 = Citroen
X = Xantia
2 = Estate
RFV = 2.0i 16V
F = 5 speed
VertVega
x 13
Yes, KFX are the magic letters :)
"In 1.4 Xsara it should be KFW (TU3JP) or KFX (TU3JP)"
x 1052
Unread post by wheeler »
You wont need the engine code for checking the airbag system. I doubt you will need lexia anyway, 99.9% It will be the connectors under the seats :)
A 1.4 will either be KFW, KFV or KFU. Depends on the type of engine, emissions spec etc.
VertVega
x 13
superloopy1 wrote:...Just out of interest, when did that 'system' of identifying engine codes come into play, roughly? ...
In MK2 Xantia engine code is added to VIN number.
_________________________________________
Edit: RGX (XU10J2TE) is the engine code 8-)
--> that must be 2.0i Turbo CT Activa (or 2.0i VSX Turbo CT)
