Hope someone can shed some light on this.
The car is a 2001 Synergie 2.0 HDI
It uses no water or oil and there is plenty of brake fluid, oil, power steering fluid and coolant in it.
When I turn the ignition, the airbag, parking brake, generator and oil lights come on exactly as they should along with the oil level guage. The glow plug circuit lights for at most 2 seconds, usually much less.
The engine starts first time every time.
(I'm making it sound as if I have nothing to complain about here.)
The only other light which comes on is the big flashinh STOP light in the centre of the instrument binnacle.
Fire up the engine and every light goes out apart from the STOP light which keeps flashing.
All the real signs from the engine, brakes, generating and steering all indicate that there isn't an issue, but still the STOP light tells me that we're all going to die in a ball of flames.
Any ideas, anyone ?
Other than this, it's going like a train.
Cheers
STOP light
- x 1460
zilspeed
Thanks very much - advice taken.
On the subject of diagnostices, would I be able to use a generic fault code reader ?
(I have a full version of VAG COM for VAG group cars and that has been invaluable.)
Having found the OBD port and installed OBDscope on my phone, I'm tempted to get a bluetooth OBD interface and use that.
Like this one http://cgi.ebay.co.uk/WIRELESS-BLUETOOT ... 414cb00eb7
Hopefully, that would talk to the Synergie.
- x 8403
I believe the pre-2004 diesels fitted to PSA vehicles (Citroen/Peugeot) are not OBDII compatible so that reader is unlikely to work.
All pre-OBD Citroen vehicles can only be read using a Citroen Lexia or one of the after-market tools that is strictly compliant (such as the Sykes ACR4).
Don't believe anyone if they say the OBDII readers will work on your car unless they prove it to you in a practical demonstration.
Toby_HDi
- x 3
zilspeed
They're all shut well enough for all the interior lights to go out when I close the driver's door.Toby_HDi wrote:Check all the doors and boot are shut properly, possibly the bonnet too.
It will flash if not.
Just found a thread on a Peugeot Forum where someone with an 806 HDI had the same issue. Cleaning a connecor located above the fuel filter did the trick. Just need to find the fuel filter first...
