Entering N reg Peugeot 306 Diesel Radio Code
mikemartin
Please can someone tell me how to enter the radio code for an N reg 306 Diesel after changing the battery. When I switch on the radio, the display just shows 4 "dashes", and pressing the number buttons on the radio has no effect at all (the numbers do not show up on the display as I press them). Thanks
spider
- x 77
It depends on the type of radio fitted.
From memory yours will probably be the Blaupunkt unit (although even on the early 306's there are at least two, base models are different)
Been a long time since I saw one or entered the code. I think you have to just press the up / down buttons to go through each number , pressing up / down to select the first digit, then press (1) , up / down again for the second and press (1) or maybe (2) etc etc.
Picture of radio would help if in doubt.
Andy.
