C5 import
- x 1056
I have done this for someone also on a mk1 C5, the instrument panel needs to be replaced with a MPH one, you do not need to replace the BSI or alter any of its settings.
With regards to the headlights, the car concerned had xenon headlights, I contacted Citroen UK about this & was told by them that xenon lights had had a straight beam pattern & were the same for both LHD & RHD so no change needed, a check on an MOT headlamp beam setter disproved this & clearly showed the beam 'kicked up' & would not pass an MOT. There are also different part numbers for both LHD & RHD.
As new xenon headlamps are around £700 each normal halogen ones were fitted instead. The halogen lamps fit straight in but you need to reprogram the BSI & suspension ECU with a Lexia to get them to work properly.
Hope this helps.
Hope this helps.
vision
KP
- x 27
- x 1056
vision
Just going back to the headlamp swap problem. I have been told that they are xenon headlamps. I have not seen the car myself yet,
"The halogen lamps fit straight in but you need to reprogram the BSI & suspension ECU with a Lexia to get them to work properly"
Will the halogen replace them?
Thanks again.
Thanks again.
- x 1056
