Has anybody suffered with the loss of their spare wheel.
Some bugger nicked mine!!!
Does anyone know if there is a security device available.
Spare Wheel Xantia
JohnD
- x 72
MW
Commiserations, Ron. It's happened to quite a few people, I gather.
A quick search through the back catalogue produced the following debate:
http://www.andyspares.com/discussionfor ... pare+wheel
Hope it helps. Sounds like there are different wheel sizes out there, so make sure you get the right one from the scrappy.
- x 1044
yes there is a locking device available from citroen,i think they are quite expensive though (and makes it a pain in the arse to get the wheel back in). a cheaper solution is to buy a bycicle chain/lock pass it through a hole in the wheel & a solid point on the car.cant remember if there are any good points to pass it through on the xantia,you'll have to have a look.
Dave Burns
- x 1044
NiSk
Ron
They cut the carrier and nicked the wheel and jack box.
The only good thing was it was a HANKOOK Tyre.
I hope they are very hapy with each other.
If I would of found them I would have dropped the suspension
OUCH!!![}:)]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Burns</i>
What exactly did they do to make off with it, did they cause any damage.
Dave
OUCH!!![}:)]
Dave
mark_sp
Hello Ron
In the past month someone at work stole my Coffee mug, just an ordinary mug and in fact it was pretty disgusting as most of the glaze on the inside had worn off. When I complained to the Tea maker he said he could top that because on the same night someone had stolen the head off his mop, not the complete mop just the head. Anyway this has got nothing to do with Citroens so I'll stop rambling.
One option would to be to dispense with the spare, it's not required for an MOT. So your not left stranded either join a recovery club or carry one of those aerosol tyre sealant/inflator things.
Don't let the B*****ds grind you down.
Mark_sp
Mark_sp
nick
Could be worse, someone tried to take one of the road wheels off my dad's Xantia a few weeks ago. They obviously got disturbed part way through as they'd totally removed one of the bolts and loosened the other three.
The first thing he knew about was part way through a journey when there was heavy vibration and a regular thudding noise from one side of the car. Fortunately he wasn't going fast, and stopped to investigate before it got any worse, could have been very nasty though.
Nick
Nick
