I've finished my cylinder head overhaul, but hit 1 slight problem, I managed to loose an injector !!!, so i now only have 3 original ones.
digging through my toolbox i found 6 spares with the correct part number on, but my originals are coded Z and the spare one i have is coded Y, i know i need to recode this into the ecu so that i get the correct flow rate, but i have never done this before, does anyone know how you do it ? (which menu its in etc..)
How do you code and injector with Peugeot planet ?
TopDonkey
- x 1043
TopDonkey
- x 1043
TopDonkey
I will take the tips off and clean up all 4 spare injectors i think and fit them as a set so that they are all the same then, thats probably the best idea till i find the missing injector, it was last seen in the kitchen near the cooker, and i'm sure my wife has tidied it away somewhere but she denies all knowledge!!
Do you know which menu the injector coding is at all ?, as i will have to change it from a Z set to a Y set now
