Hole in sump
dturbo
Hole in sump
Just put a hole into the sump of my 405. I believe the cheapest option would be glue it. Anyone done this and what do you recommend I use?
TopDonkey
Is there a glue that can withstand temperatures of 130 degrees centigrade ?, the sort of environment that the sump is in is very hostile, i would suggest as a minimum bodge repair that you could make and oiltight gasket and put it on a metal plate that you could rivet to the sump from the outside ?
Sumps are so easy to take off though on most cars, that its probably going to be easier to get a new sump from teh scrappy and fit it
- x 94
dturbo
TopDonkey I don't think it is easy taking the sump off a 405 as far as I could see. A fellow owner please confirm.
citronut the hole was near the corner and a funny shape a tapped wouldn't work I think.
In the end I didn't feel comfortable doing it (maybe because I'm useless
) so took it to a mechanic.
He glued it with another piece of alu (which I'm now reading should be done) but seems to hold for these few days so pretty happy.
- x 1060
- x 94
- x 1060
