lx height adjustment
dawn64
Unread post by dawn64 »
the front two spheres were changed last year, the two back were done 2 weeks ago, but now i have a problem with the ride height of the front. When the car is parked the front height is heigher than it should be and the back is lower, the fluid has been topped up, can you please advise how i can solve this problem,
cheers
dawn :lol:
x 94
Unread post by citronut »
hi Dawn and welcome
the first thinkg to check and make 100% sure the hight corrector external linkages/mechanisum/s are fully freed off and not sized up,
unless someone has altterd or adjusted/tinckerd with the fixed hight adjustment, they do not usualy go out of adjustment on there own
regards malcolm
dawn64
hello malcolm
WOW :shock: thanks for the quick response,
no body has adjusted it so i will check it have not seized up, if the front has seized up will it effect the height on the back?, i have a difference in space of a fist on the front and one finger on the back when the car is parked
CHEERS
Dawn
Old-Guy
x 24
Unread post by Old-Guy »
Hi Dawn
I'm assuming you have a Xantia? You might like to add model, body (Hatch/Estate), engine and year to your signature.
Are you sure you have a problem? The rear arch on Xantias is flattened at the top, so it's normal to have less clearance at the rear. The crucial check is to park the car on the level, get out leaving the engine running and give the suspension time to settle. Stand well back - the bottom of the sill should be more or level compared with the ground.
Also, it's perfectly normal for a Xantia to take 10-15 seconds to adjust the suspension to a change in load (even just someone getting out of the car)
Next, as spheres have recently been changed, you need to give the c been give the car a good session of 'Citarobics':
With the car parked with hand brake on, doors closed, steering centred, and the engine running -
1. move the height control lever to Low (most forward position) and wait for both ends of the car to sink right down.
2. Move the lever back one notch to Normal and wait for the car to settle at both ends.
3. Move the lever back one more notch and again wait wait for the car to settle at both ends.
4. Move the lever right back to High wait for the car to settle at both ends.
Reverse the sequence.
Repeat the whole UP and Down sequence 3 or 4 times.
This will expel any air in the system which will cause weird effects.
dawn64
Re: lx height adjustment
hello i have a citroen xantia estate 19td lx p reg ...............
i have tried the up & down thingy, several times, and the front it still high when parked
cheers
dawn
MikeT
x 232
Unread post by MikeT »
Hi Dawn,
Might just be the plastic clip has popped off. If you can get the car supported properly, take a look at the front height corrector. You're looking for a short (about 3 inches long) white dog-bone shaped plastic clip. It has ball cups each end and one of those might have disengaged leaving the car with no height correction.
x 94
were abouts are you Dawn
regards malcolm
dawn64
Hello
i will have a look for the connector when i can get the car on a ramp, cheers for the help
i live in South Shields
Dawn
