Hi!
Reading here I decided that I am enough enlightened to check my car. Ignoring couple of burns it passed OK [:D]
Here the facts, which I think have concern to the subject (sorry if no).
Accumulator sphere was never replaced or regassed.
Pressure regulator clics each 5-7 seconds.
After "citrobix" (4-5 times) I opened pressure releive valve-nothing was hear.
After 10-20 hours of parking red emergency lamp lights up and breaks operates with delay. In 5-15 seconds it becames OK. Here I don't understand: if sphere is flat-LHM does not force out by gas-so it remains in the sphere-why it takes a time to refill the sphere?
As I understand -all symptoms of flat accumulator sphere.
Am I right?
Something done wrong?
What is normal clicking frequency of pressure regulator? In Zelico Nastasic's manual 20-25 sec for BX is OK. Is it the same for Xantia?
Any reply or suggestion will be greatly appreciated.
Best regards
Hydraulics testing
The delay is due to the rest of the system being pressurised not the accumulator, get a new one stuck on because if you can't hear fluid being forced out when the release screw is opened it means the sphere is totaly flat, so you have no safety reserve if the engine stops or the pump drive belt breaks.
The cut in frequency of the regulator depends also on the general condition of the hydraulic system, not just how much gas pressure is in the accumulator sphere, but as a rule of thumb with a good sphere the clicks can be anywhere from 20 seconds to 2 minutes.
Dave
Dave
<font color="purple">...you have no safety reserve if the engine stops or the pump drive belt breaks.
Dave</font id="purple">
Thanks Dave!
I'll replace the sphere.
By the way-now I tested the breaks with engine stopped-It works enough[?] good. Two-three times it functioned-each time more weakly, but works.[^]
Thanks Dave!
