Seeking Suggestions re Accessing Xantia Headlight
Peter Mann
Unread post by Peter Mann »
I've decided to brighten the headlights in my '94 Xantia by installing relays for Hi & Lo Beam, and fitting 100 Watt globes on
Hi Beam (legal in Australia, where powerful lights assist seeing the hazardous wild kangaroos grazing on the roadside).
Inserting extra wiring into the harness looks like it may be easiest done by removing the headlight assemblies to improve
access. I've removed the two 10mmAF bolts that hold the top of the headlight to the crossmember, and plucked out the
turning indicator, but no sign of what to do next, nor indication of how regrettable doing it might prove.
algieuk
Unread post by algieuk »
There is another 10 mm bolt underneath the headlight unit you will need to remove after you have taken out the grill. Then the headlight can be eased out bottom first.
