Xantia - Draining the tank
gadgetgricey
Unread post by gadgetgricey »
I've just done a stupid thing and put petrol in my diesel Xantia. (Had filled the wifes Scenic up before, and just went back to the same pump :oops: )
I realised mid "pump", so will probably be OK, but is there an easy way to drain the tank.
Got me back home Ok, but just thought it might be worthwhile.
Thanks again
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Struth - easy way to kill the injector pump, I'd think! What about picking up an external EFI pump from a scrapper, and using a length of hose into the filler neck? Hose on the other end into the jerry can - not sure what you'll do with the mixture.
TopDonkey
Unread post by TopDonkey »
and XUD probably wont even care that you half filled with petrol !, they arent as picky as HDI's
but i would add some 2 stroke oil into the tank for pump lubrication, about 2 litres should do, them brim the tank with diesel and drive it as normal
Chlorate
Unread post by Chlorate »
You could detatch the hose leading to the fuel filter and use the primer bulb to drain your tank.
Would take a while though :lol:
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
Gingerposer
x 6
Unread post by Gingerposer »
I have had to drain a tank recently when I scrapped a car unexpectedly.
Try your local motor factor or tool store for a drill powered pump. Simply attach to an electric drill, couple of lengths of plastic tubing (normal garden hose worked for me) should do the trick - or you could do it by siphoning.
If you do use the drill pump method, be aware that you may need to prime the device by siphoning some fuel with the hose first before connecting to the pump.
Also, the pump will be toast after you do this cos they are not designed to pump fuel. But they are not expensive.
http://www.toolshopdirect.co.uk/item.ph ... /sn/868760
shows an example very similar to what I used.
Good luck!
Ainslie
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Bulb primer!! Under the bonnet.. as sugested above.. It doesn't really take too long.. you hand might be a bit tired and achey during the process though.. :lol: :wink:
Paul
A very sad...
1994 XM 2.1 d auto
TopDonkey
you could try parking in the dodgy end of Liverpool for half hour, you will probably find someone has helpfully drained your tank for you by the time you come back :D
lexi
x 133
Unread post by lexi »
Or the dodgey end of "any city" :lol: How much petrol have you put in and how much diesel was in tank already is the question ?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8408
I would get as much out as possible. Bosch mechanical pumps are tough but they won't appreciate pumping petrol as it has no lubricity at all and could well damage the pump severely.
Popping some two-stroke oil in is a good idea though :D
Xaccers
x 188
Unread post by Xaccers »
Did the 1.9D always have a bosch or did they get the lucas too/instead of?
DIY sphere tool
x 8408
Xac wrote:Did the 1.9D always have a bosch or did they get the lucas too/instead of?
Many 1.9Ds had the Lucas pump and if this one does, then petrol contamination will be even more detrimental to it than to a Bosch...
gadgetgricey
All out, boy my right hand is sore after all that pumping. :shock: :lol:
Got plenty of fuel now for burning all the wood in the garden.
Thanks to everyone for your input.
Cheers
- Dave -
x 8408
Well done Dave :D
gadgetgricey wrote:All out, boy my right hand is sore after all that pumping. :shock: :lol:
Been there :roll: Xac and I once pumped 40 odd litres of veg. out of a 1.9TD tank using the priming bulb :lol: :lol:
Toby_HDi
x 3
Unread post by Toby_HDi »
Just a quickie to add to this one.
Is it wise to drain fuel from a petrol by removing the feed to the fuel rail and using the ignition to operate the lift pump? Or is this a definite no no as I'm thinking due to the risk of fire?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
VertVega
x 13
Unread post by VertVega »
Toby_HDi wrote:... Is it wise to drain fuel from a petrol by removing the feed to the fuel rail and using the ignition to operate the lift pump? ...
I've seen this operation done in a repair shop, on a non-Citroen car.
Without starting the engine(!) they were able to get fuel for about 3 seconds
because a relay under dashboard was cutting off fuel supply.
Finally they replaced relay with a piece of wire for a non-stop fuel flow :roll:
