Is it possible to transfer all the workings from the drivers side electric window from a MkII to a Mk I.
Aware from reading some of the posts that the workings are different, so wondered if a full "transplant" could work.
If so, how the hell do you get the workings out. Currently at door panel off, foam off, and all the bolts removed (that I can see), but I cant "see" what to do next.
I'm assuming I've got to disconnect the glass from the frame, but cant see any bolts.
As always, any help would be great.
Thanks again.
- Dave -
Xantia electric window change, Mk II to Mk I
- gadgetgricey
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Glass is attached by a CLIP... you need to lower the window down untill you can see the attachment in the hole in the door skin..
S2 cars are a metal long type clip that you need wonderfully long fingers to get round the opposite side of the glass to remove the clip..
S2 window winder on the drivers side only (Except Exclusive Trim) have the one touch and anti pinch built into the motor!
The motor and winder cableing will fit into a S1 door and vice versa..
Window runner attachment is at the opposite ends of the runner if you follow it to the top, the nut may be hidden behind foam, same for the rear, and the motor has 3 fixing screws on the motor to the front of the door..
Unfortunally Xantia harness's are hard wired to the main car unlike 306 and XM's were as theres a plug in the A pillar.. so you need to feed out the wireing after unclipping the plugs from the parts in the door...
You will then have to solder each and every wire inside the car to replace the S1 door harness..
Its much easyer to forget the anti pinch and just put in another winder unit from another S1 Xantia with one touch..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- gadgetgricey
Thanks for that Paul, but can you clarify..
Thanks again.
- Dave -
If I'm not bothered about one shot, or auto pinch, can I just change the motor and cabling. Basically the window has dropped/failed on my Mk I, and I was hoping to canabalise the bits from the mk II.citroenxm wrote:
Paul
Thanks again.
- Dave -
