C5 Hazard lights
amjake
C5 Hazard lights
Unread post by amjake »
Hi All
Simple one I hope.
Using Hazard light switch on centre of dash (red button) lights flash, indicated in instrument binacle but the red switch doesn't flash.
Is it meant to? If so how does one remove to replace bulb?
Kevin
miked
x 6
Unread post by miked »
The switch in my xsara doesn't flash either when the hazards are on, but it does flash when the alarm is set. Maybe the C5 is the same?
Citroenmad
x 110
Unread post by Citroenmad »
Yes it should flash. Only the small triangle lights, but it does flash when your using the hazards. It also lights when your headlights are on. Does yours?
Not sure how you would go about replacing the bulb, might be a new switch.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
