I'm getting on the ball with this Lexia now.
I decided to read the codes off the missus HDi and see if i could figure out any reasons for it smoking or generally being a pain in the ass.
Here's what I got from it:
ABS ECU:
Intermittent Fault - Safety Relays
Engine ECU:
Permanent Fault - 2 additional heating and preheating circuit - Faulty Circuit
Temporary Fault - ECU Microprocessor Internal Fault
Temporary Fault - Flowmeter signal - Short circuit to earth or open circuit flow too low
Temporary Fault - Pre-Post heating relay circuit. Short circuit to positive
Temporary Fault - Pre-Post heating relay circuit. short circuit to earth or open circuit
Temporary Fault - Fuel low pressure pump supply. Short circuit to positive
Left Airbag ECU:
Permanent Fault - Warning lamp open circuit
Suspension ECU:
Intermittent Fault - Steering wheel sensor
Intermittent Fault - Speed Sensor
Intermittent Fault - Accelerator Pedal Potentiometer
Intermittent Fault - Incorrect accelerator pedal adjustment
Intermittent Fault - Straight ahead calculation
Would the faults from the suspension explain why the car lifts the rear when you lift off the throttle and why it dips the rear when you put your foot down?
Thanks Guys
David.
Xantia HDi Exclusive Fault Codes
DHallworth
- x 167
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1459
DHallworth
- x 167
OnlineRichardW
- x 1488
The first one coule be a duff glowplug or two - apparently most older HDis have at least one plug down, as they have a hard life with post start heating. The others I'd just wait and see if they come back - as mentioned above, could just be a low voltage wobble or something.
PS interesting to see you have a Lexia now....I'm not far down the road in Lanark, so if I need a 'plug in' I might be waving some beer tokens in your direction...
Did you buy a Lexia 3 clone, or manage to get hold of a 'proper' Lexia 2? I'm still thinking about buying one - probably right up to the day I need it!
HDI
- x 7
to the OP , which Lexia do u have ? I need to buy one and the one u have seems to work well
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
DHallworth
- x 167
HDI
- x 7
citroenxm
- Fallen Hero
- x 70
I bought one too!! And they work perfectly.. Setup is a little confusing, but after help from David, got it sorted..
There seems to be NO DIFFERENCE in its operation what so ever.. making sure you get the correct leads seems more important.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lexi
- x 133
DHallworth
- x 167
http://cgi.ebay.co.uk/LEXIA-3-CITROEN-P ... 518fe0df24
That's a link to the one I bought.
I contacted the seller directly and said I needed the 2 pin, 16 pin and 30 pin plugs.
She then came back to me with a price including postage.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8386
That's a good deal on the Lexia 3
The suspension faults are pretty typical of an ECU not reset for a while. If they cleared Ok and have not reappeared in a few hundred miles than as Mike says, just glitches
You will find the Steering Wheel Sensor and Straight Ahead ones come back with regularity though. No reason, they just do. A regular Lexia'ing is a good idea on the suspension ECU and it seems to sharpen things up a tad after clearing faults.
Can't see they have any bearing on the dipping and rising at the rear unless you have a set of real comfort spheres on the back making it incredibly soft...
Toby_HDi
- x 3
Slightly OT...
Is there any difference between the Lexia 3 and the 2? More specifically is there anything the Lexia 2 can do that the 3 can't?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- x 8386
Toby_HDi
- x 3
DickieG
- Monaco's youngest playboy
- x 33
I believe that Chinese Lexia 3's can't recode keys, I'm also unsure as to how you'd use a breakout lead on them. Other than that I'd have thought that they will be similar, the only way to tell is to directly compare them side by side, project for one of the summer meets?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
