xantia driveshaft
toofargone
xantia driveshaft
Unread post by toofargone »
I have a 1997 1.9td estate. Will a driveshaft from a hatchback fit this. I know the brake discs are bigger on the estate--but assume the driveshaft would be the same.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Should do! Estates are only longer, NO wider. What year hatch are they comming from, if its the same year, should NOT be a problem.
PAul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
i agree with Paul also as long as both have or not ABS
regards malcolm
