Xantia brakes, bleed nipple?
Toby_HDi
- x 3
Need to buy some tubing to bleed the brakes with once things are finally back together. What size diameter tube is suitable. Not being able to go anywhere I'm having to order online. Halfrauds have some washer tube in 3/16" and 1/8". I know the nut on the nipple is 8mm but not sure what size tube is a good fit.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Xaccers
- x 188
Toby, PM me your address and I'll post you the pipe I use.
Got it from B&Q for next to nothing so it's easy to replace.
DIY sphere tool
DIY sphere tool
Toby_HDi
- x 3
Thermonuclear
VertVega
- x 13
That's one of the reasons why this forum is so unique and great.Xac wrote:Toby, PM me your address and I'll post you the pipe I use.
I use a transparent pipe which helps to see possible air bubbles flow from the nipple into a jar.
Inner diameter is 5 mm and I guess nearest is 3/16".
