Hi there ,
Anytbody know if an 306 , 2000 model , would have the dreaded heater matrix , buried somewhere in the depths of the engine bay !
When my wife starts the car , the windscreen is clear , after a few minutes the screen mists over , with the heater on .
anybody got any ideas ?
Terry .
306 condensation
spider
- x 77
Assuming you do not have the re-circulation switched on (should be off in most circumstances) it does point towards the heater matrix
If it is that it's not a very nice job to do on a 306, from memory the "book" time is about 9 hours in the workshop (slightly over one working day)
However, before going to such lengths (!) , carefully check for any water getting into the car especially door seals etc, look for small puddles or anything inside the car, water will cause it to condensate.
Andy.
- x 5683
As long as it doesn't smell of antifreeze it is probably not the matrix. Could be moisture retained in the aircon system or a damp pollen filter. Mine does this but clears pretty quickly with the screen clear button pushed for a minute.
The trick is to switch off the aircon a bit before you stop the car to give the exchanger time to warm up and lose any ice/condensation or it will just blow this into the car on startup - I always forget to hit the economy button too
Using the aircon on startup helps to remove moisture and alleviate the misting.
Dommo
- x 20
- x 5683
Dommo
- x 20
mark21td
I've fixed a leaking matrix on a 306 with some of this
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Works a treat as long as it's not too far gone, and it's a lot easier than removeing the dash
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
