Hiya, got a xantia s2 exclusive estate, suspension seems to be very hard and stiffens up when hydractive is on. I'm getting new corner spheres fitted tomorrow, hopefully that will fix it?
If you put the suspension in high it will rise but if you select medium again it won't go down until you select low then select medium. Any ideas?
Xantia s2 HDI Exclusive Suspension
Chris570
- x 36
red_dwarfers
- x 58
Re: Xantia s2 HDI Exclusive Suspension
Not sure about the first question but the second is almost certainly mucky height corrector linkages. Is it on both the front and rear of the car you get this trouble or just one end?Chris570 wrote:Hiya, got a xantia s2 exclusive estate, suspension seems to be very hard and stiffens up when hydractive is on. I'm getting new corner spheres fitted tomorrow, hopefully that will fix it?
Take a look at this for details on cleaning them.
Kev
'19 C4 Cactus 130 Flair
andmcit
- x 30
It may very well be the case that ALL 6 spheres for the hydractive are
near flat - the corner 4 are doing the main work all of the time (even in
hydractive mode) but the real cushioning is felt by the middle spheres on
each axle being electrically switched in which in practice are what give the
car the softness of ride. What I'm saying is the middle pair could be
renewed first and you find the ride noticeably improves whereas the
corner spheres just being renewed may make little impression on the
ride as the flat middle spheres are still fitted!
You could try hydraflush to clean the hydraulic system and exercise the
height lever through the extremes as it sounds you already are. In the
end it may come down to a stiff mechanism linkage on one of the height
correctors. Needless to say, take care under any hydraulically suspensioned
Citroën as you could be flattened! Check out Jim's guide in the Stickies
section of the forum for a guide to all the key hydraulics.
Andrew
Andrew
Chris570
- x 36
andmcit
- x 30
Check the part number usually printed on the sphere that's new to confirm
it's the right fitment; won't be tge first time the wrong one is supplied/fitted!
Corner spheres it likely is then though hydraflushing and cleaning the
LHM side of things will work wonders for the ride!! Try entering a search
in the top right dialogue of this forum with "accumulator" and "height
corrector" which will likely provide hours of reading for your reference!!
Andrew
Andrew
Chris570
- x 36
Xaccers
- x 186
dogbone links popped off or broken?
Height corrector links seized?
DIY sphere tool
DIY sphere tool
Chris570
- x 36
andmcit
- x 30
Granted, if the car IS finding the heghts the anti roll bars and the links
seem to be there and trying to work. It may very well be purely down
to fine adjustment of the height selector linkage: this can sometimes get
bent out of true where the car has bottomed out or not fully lifted up to
running height when driven off a kerb etc.
Are both front and back matched in their height behavior or is one end
trying to work at correct height level?
Andrew
Andrew
Chris570
- x 36
andmcit
- x 30
Should the rear height corrector linkage be all seized up you'll never benefit
from the suspensionoperating in it's correct attitude even with decent
spheres (middle or corner). It's likely a good careful examination of the rear
corrector, it's linkage as well as the plastic dogbone and small arm off
the anti roll bar is required and adjustment/lubrication as needed. Would
you say the ride heights looked right on the normal middle setting?
Andrew
Andrew
MJM
I think I read a post from either Old Guy or Handyman explaining why you can't go from high suspension setting to medium. From memory it's not a fault, just a feature of the system.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
Xaccers
- x 186
I think by medium Chris is referring to normal rather than the intermediate (slightly higher than normal) setting.MJM wrote:I think I read a post from either Old Guy or Handyman explaining why you can't go from high suspension setting to medium. From memory it's not a fault, just a feature of the system.
DIY sphere tool
DIY sphere tool
Chris570
- x 36
sorry, yep i was xac (should have stated, my bad)
visited martin at pleaides (sp) today and the rear spheres were FUBARD and the fronts were only at half pressure, he changed all 4 round and my god what a difference, rides like a citroen now
rear height correcter is the problem as the front is now playing ball.
cheers guys
cheers guys
Pleiades
