Can anyone tell me how I can find out which manufacturers ABS is fitted to my sons' Xantia - Bendix or Bosch?
It's an X reg. (2000) 1.8, 16valve hatchback.
Dave.
Xantia ABS
DaveW
Xantia ABS
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
citroenxm
- Fallen Hero
- x 70
Neither, Its a Tevis system...
Not sure exactly which model, but ALL Xantias had Tevis system, but S1 cars to 1998 had one version, and 1998 onwards had a revised system but still Tevis..
Paul
PS: Is that North Wales or South Wales, your location?
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DaveW
Hi, Paul
Officially it's North Wales but we are kind of in the middle - 25 miles inland and slightly to the north of Aberystwyth.
The reason I asked about the ABS is that his car is in a garage(non Cit) with a broken O/S ABS ring and the mechanic needs to know the info in order to get a replacement.
Looks like it will be a new driveshaft!
Dave.
Dave.
Dommo
- x 20
DaveW
Dommo
- x 20
DaveW
Dommo
- x 20
citroenxm
- Fallen Hero
- x 70
Ah Dave your central wales... shame if you werent closer...
You CAN get the rings on their own and heat them on, cheap enough here:
ABS Rings!
Damm sight cheaper then a drive shaft!
Paul
PS: Yes Tevis, Teves, which ever way you spell it Xantia only ever used Tevis/Teves
ABS Rings!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DaveW
Paul,
Thanks for that. I will knock the old ring off and measure the seating diameter.
A much cheaper option if the diameters match.
Many, many years ago I did a similar job with a Ford Anglia starter ring - popped the flywheel in a freezer for a couple of hours, heated the ring and it just slipped on sweet as a nut.
Dave.
Dave.
