306 TD gear and diff ratios
sv4195
Unread post by sv4195 »
Xantia gearbox is now on the floor and can be used as a door stop . The diff collapsed and punched two holes into the bellhousing.
Mechanic has rung round checking ratios etc and we will end up with an E3(?) box from a diesel 306 from our local breakers yard. Fingers crossed eh?
Can anyone point me to gear and diff ratios for a 306 diesel (non turbo I think)? (posted on the Citroen forum as http://www.andyspares.com/discussionfor ... IC_ID=2941)
rossd
Unread post by rossd »
N/A diesel 306, Box type BE3/5 N, id code CL77.
1st 0.2894
2nd 0.5348
3rd 0.7812
4th 1.0322
5th 1.3214
Final Drive 0.2539
Hope this helps!!
Ross
rossd
TD 306, Box Type BE3/5 LKG id code CL79
1st 0.2894
2nd 0.5348
3rd 0.8709
4th 1.2068
5th 1.5200
Final Drive 0.2539
Sorry, thought you might need the TD box too.....!
Ross
