Picasso 2.0 HDI continued!
Lawrence1973
Unread post by Lawrence1973 »
Really had no luck tracking down this strange sound.
Crank pulley looks almost brand new, aux belt has seen better days but the sound isn't audible from the belt or the engine bay.
I have noticed a few oil leaks - one accumalation of oil under the air con compressor, oil around the breather on top of the gearbox (is this bad?)!
The gearbox does sound a bit louder than I'd expect.
Is there anything neutral in the gearbox that would make the whining sound? It makes no difference pressing the clutch.
Just to add to the fun, the dash lights go dim when I turn the headlights on!
Any thoughts?
DickieG
Monaco's youngest playboy
x 38
Re: Picasso 2.0 HDI continued!
Unread post by DickieG »
Lawrence1973 wrote:Just to add to the fun, the dash lights go dim when I turn the headlights on!
Sounds normal to me as the dash will cause glare if it didn't.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Lawrence1973
How right you are, just read the manual.
It was on the lowest setting - when I turned the lights on before it looked like an earth fault!
Always read the instruction manual :oops:
