Filler flap locking pin,
Gregg1100
x 5
Unread post by Gregg1100 »
Both my sons and my cars filler flap locking pin seems to have seized in it's tube. Obviously when the flap is shut :shock: . They were both ok till we had all that snow. How does one get behind it to remove it so I can either repair ( glug it full of Plus Gas ) or replace.?? The pin does shoot back in occasionally, but not when I need the flap open to get fuel, :?
Thanks,
Greg
Both cars are Xantia 2's--mine a 1.9td, his an HDi110
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Xantidote
x 4
Unread post by Xantidote »
I was fortunate to find the pin on my filler cap to have seized in the recessed (unlocked) position, and I only discovered this when I noticed the filler flap wafting about. Applied 3-in-1 oil spray which penetrated enough to get the pin to ultimately protrude, which I then attacked with emery to remove rust from pin, followed by thicker oil & grease. Since worked for last 3 years, and thanks, you've reminded me to oil it again - good preventive maintenance. Seemed a lot easier than trying to somehow remove device completely.
With the pin in locked position, there's just enough gap between the body and filler flap to see the mounting bracket (washer?) of the mechanism, and if your panel is stuck shut, then I'd have thought you might be lucky enough to free it by squirting in copious amounts of WD40 or Plus Gas in that vicinity. Certainly enough gap on mine to get the thin nylon applicator tube into the gap. Good luck :)
Martin
1995 Xantia TDLX (deceased :( )
Clogzz
x 40
Unread post by Clogzz »
The spaghetti. :wink:
RoyChristie
Unread post by RoyChristie »
:cry:
