its a mystery..
Blackdog
its a mystery..
Recently when I start the Xantia up after a few hundred yards she develops a "light" rattling sound coming from what feels like right under the drivers seat....it sounds like Ive left a spanner in there after working.....its not a knocking sound its a continous roll on roll off "spannery" sound...recently Ive been working under the car and didnt really have time to fully look at what could be causing it but did have a look all down the drivers underside but nothin obvious...whats right under the drivers seat anyway?? it all looks pretty sealed off to me...I just wonder if anyone knows what I should be looking for....its not the exhaust either...!! its a mystery..and needs sorted.
I.9TD Green xantia estate sx 96.
1.9TD Green xantia estate sx 99.
Kowalski
Blackdog
Thanks for the reply I dont think it is a heat sheild as I checked that but am going over to a friends today and we will get to the root of it I think its something quite major but not obvious as I said its a mystery but hope to get to the root of it over the weekend...will give a post to let you know the result!!
- x 94
falling-out-with-my-car
- x 25
Nothing under the seat to cause this I reckon its the rear seat back chattering in its latch if not it could be the rear O/S belt clip upper half banging against the door mouldings I shove this down the side of the seat to stop this.. more likely to be the metal upper seat latch my parcel shelf also makes that kind of noise sometimes.
to stop the O/s rear seat back latch from chattering add a little copper grease to the latch it'll soon stop. if you fold the lower section of the rear seat forward and oil the metal rod underneath it this might also improve your situation.
regards Nigel.
regards Nigel.
