odd radio code
odd radio code
about a year ago I posted a thread requesting help with radio code.. a year on and a very usefull link being set up with an online calculator made me think it would be pretty straight forward to get the code for my new xantia...the problem is that you get at least 3 codes to try and most probably one of them will work it did the last time however the radio I have now is a 4035 and although the preset buttons are numbered 1-6 like the old ones if I am given a code with a number more than 6 the system wont accept it.....because button one is number one button 2 number 2 and so on....is it the case that a radio system 4035 can only have a code between the numbers of 1-6 and if so how can I get it from the link that has been set up when they give me numbers beyond 6 which I cant input to the system without it locking...work that one out!!
I.9TD Green xantia estate sx 96.
1.9TD Green xantia estate sx 99.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Radios on 1999 Xantias have a completely different code system to ealryer radios.
Series 1 radios to 1998 are Blaupunkt, which can be decoded on line and a code from 0001 to 9999, were as S2 radios can only have codes from 0001 to 6666 and need the code reading from thechip memory and not calculated from the serial code..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Gingerposer
- x 6
Radio code
Or get in touch with this chap
restoredclassic@aol.com
you'll need all the info from the stickers on the unit, only asks for a small paypal donation to provide with a code. Sorted mine out in a few hours. The car is a w reg (2000) with a philips radio but he can do other makes also.
Ainslie
Ainslie
