xantia air/con cooling fans heater fault
craigo
Unread post by craigo »
Hi looking for some help my 2001 xantia hdi has no cooling fans no heater blowers and no air/con the heater blower has been having an intermitent fault stops working then suddenly starts working usually when car gets hot and cooling fan cuts in but now the cooling fans have stopped working can anyone send me in the right direction. have went through search after search on this forum but most problems are one or another not all together.
Thanks in advance
Citroen xantia 2000 hdi estate 110bhp
Fiat ulysse 2003 jtd
Suzuki 1999 gsf 1200 bandit
rory_perrett
Unread post by rory_perrett »
The 3 faults you have may not be connected. I've just had to fix the heater fan on my 2000 Xantia. For the last week it has required a kick up the back side so to speak to get it going. Well a thump or kick on the carpet under passenger side dashboard where the fan is located. Had cooling fan problems in the passed due to the relays situated between the fans not making proper contact with their plugs. Have a go at fixing them individually first.
