Hi all,
Does anyone know the inside diameter of the water pipes that go to and from the heater matrix?
I ask because I want to flush out the matrix to improve cabin temperature. And I don't want to break the elbows on the matrix.
I am thinking of cutting the pipes to flush and then re-connect using in line connectors.
Xantia heater matrix pipes
Martin Beevers
95 Xantia 1.9TD SX - Now sold
DickieG
- Monaco's youngest playboy
- x 33
If you are going to cut pipes then the only way I can see to do it is to cut the rubber hoses at a convienenit point between the matrix and engine. I think a 15mm piece of copper pipe will do the job, just make sure you run a bead of solder around each end to prevent the jubilee clip being pushed off when at pressure.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Martin Beevers
Xantidote
- x 4
lexi
- x 133
If doing stuff like that then a brass olive soldered in place is a good substitute for a swage.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
