David Conway from the CCC has asked me these questions regarding his C5,
David wrote
"Re/C5
What can you tell me about
a) Warning that I have a puncture
b) 12v socket that is dead (Not the fuse, I do.t think)"
regards malcolm
C5 questions
Trainman
- (Donor 2018)
- x 43
Morning Malcolm,
1. Has the tyre been recently changed on the affected wheel, if so it could be the pressure sensor, they can sometimes get damaged.
2. I guessing that if the fuse isn't dead, (stating the obvious) has something else been plugged into the socket that is known to work?
Steve
http://c6owners.org/index.php
- x 94
AndersDK
1) the pressure sender unit is located as part of the inflation valve unit inside the rim.
It is powered by the external receiver unit located (emitting a weak field) somewhere in the wheel arch.
I'd suspect the external unit or its cabling
Note that aftermarket alloy wheels wont have the valve sensor unit and therefore the system will signal a low tyre pressure warning.
2) later cigar lighter (utility) outlet sockets are known to be of poor quality
Anders (DK) - '90 BX16Image
- x 1056
