Lowering Suspension No Engine
acrowot
I have a 1999 Xantia with a snapped Cambelt, engine Goosed with no Auxcillery Belt. I want to remove some parts that require that the Suspension be de-pressurised, is it possible to do this as the pump cannot be run in the normal manner.
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
citroenxm
- Fallen Hero
- x 70
Yes you CAN activate the pump manually..
If you carefully remove the nuts around the pump securing the pipe work first, then remove the two mounting bolts that hold the pump in place, you can fit a 13mm headded bolt to the centre of the pump, then make an adapter that will fit a 13mm socket and fit in a power drill
You can then use the drill to spin the Pump to build up the system pressure.. If you put the car in low setting she will then sink..
BE AWARE: The pumps are a good quarter horse or so! you will need a VERY POWERFULL drill, as the drain on a lower powered drill CAN burn it out.
But thats how I do it and it works well to, if your anti sink works its also a good way of getting the car up to tow it..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Just thniking about it, are you not going to fix her up??
They DO NOT break the Cam shafts like the old engines, just the rocker fingers, so theres NO need to remove the head to fix her???
PAul
PAul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
acrowot
Thanks for your reply, no I am not fixing it, it is the 1.9 td and I have replaced it with a HDI, the Camshaft pulley is split and when I turn the camshaft using the nut sequring the pulley it does jam, I think a Piston or Pistons have come into contact with some of the valves. Before the Aux. belt shredded and some of it got under the Cambelt and caused the belt to jump a few teeth it was in good condition. These cars are very cheap now and I decided not to repair the faulty one.
citroenxm
- Fallen Hero
- x 70
addo
- Sara Watson's Stalker
- x 95
Easiest "crack" for suspension pressure is to loosen the input pipe nuts to a strut top (front suspension) or into a suspension cylinder (rear suspension). Do not fully remove the nut, keep it in by a thread or two and carefully pull the pipe away. Be wary of the fluid jet - messy and high pressure.
Setting the height lever to high first, might help.
acrowot
Xaccers
- x 188
Belt snapped on Cassy doing 40mph on the M25acrowot wrote:Thanks for your reply, no I am not fixing it, it is the 1.9 td and I have replaced it with a HDI, the Camshaft pulley is split and when I turn the camshaft using the nut sequring the pulley it does jam, I think a Piston or Pistons have come into contact with some of the valves. Before the Aux. belt shredded and some of it got under the Cambelt and caused the belt to jump a few teeth it was in good condition. These cars are very cheap now and I decided not to repair the faulty one.
Broke the cam and it's caps.
Sourced new ones for about £50, fitted and good as new.
The valves rarely bend as they are inline with the pistons.
Great engines, much better than the hdi
DIY sphere tool
DIY sphere tool
lexi
- x 134
handyman
Hullo Acrowot, to answer your question, that seems to have gotten overlooked, yes, you can depressurize the system without the engine running.
Simply switch on the ignition, move the suspension level lever to 'low', stick your head under the bonnet and open the pressure bleed valve on the regulator block, 12mm head, next to the accumulator sphere. That should release the pressure in the system, sufficient to remove parts, assuming they are not spheres as you will need maximum pressure to 'crack' the joint on these.
Handyman
Handyman
Xantidote
- x 5
handyman
acrowot
Thanks Hanyman will give this a try.handyman wrote:How do you de-pressurise the system when removing spheres? Does the anti-sink stay pressurised?![]()
All the ones I do sink to the ground. There may be a small amount of residual pressure, but it is nowhere near full operating conditions.
Handyman
Xac, In what way is the 1.9TD better than the HDI?
Xaccers
- x 188
Well, you can repair the damage done by a slipped/snapped cam belt easily
Runs on vegetable oil so is much cheaper.
Spares are readily available from most scrap yards again reducing the cost of ownership.
Easier to tweak for more power.
Fewer complicated parts to go wrong.
Available in the better looking S1 Xantia rather than only in S2
DIY sphere tool
DIY sphere tool
acrowot
Xac wrote:Well, you can repair the damage done by a slipped/snapped cam belt easily
Well I would not and do not run on veg, so for me that is not a reason to prefer the 1.9 to the HDI.
There did used to be many of the old Xantias in my local scrappy, there are non there now but the HDIxants and Pugs are now begining to appear.
I have a HDI90 and am led to believe you can chip or remap these quite cheaply, but will not be doing it anyway.
Complicated parts, yes OK.
Available in S1 that is better looking, not in my opinion.
I also find the HDI smoother and more economical.
I have had a few Xantias over the years, one I bought with a snapped Cambelt, valves in this were bent, I souced a skimmed and allegedly recon head, this also had 1 bent vale, it was a pig to remove.
So most of your reasons seem to be your own personal opinion which are not mine.
