gearstick disconnected?
john_csfweb
i have a 306 and when i went to start it today it was as if the gearstick was no longer connected to the gears or something. it is just loose so i cant put it in gear. it was fine last night, just wandering if anyone else has come across similar problems? cheers
- x 8448
Hi John,
Welcome to the forum
This is an easy one. You'll find one of the ball-jointed linkages between the gearbox and selector rods back to the gearstick has fallen off. One end of the balljoint on each link rod is embedded in rubber. Usually the rubber breaks up and the linkage falls off.
Superglue will effect a (very) temporary repair but replacement is the complete answer.
Often the splits if they are roughly handled during a clutch change.
The linkages are not easy to see. Have a look at the back of the gearbox and you'll see three of them.
You don't say which engine/gearbox it is so I'm assuming a BE3 above. If it's a small engined model with the MA gearbox then an additional common cause of this is the roll pin on one of the selector rods falling out.
evilally
- x 3
spider
- x 77
Access is not bad
Maybe need to whip the battery (possibly airfilter depending on model) out so you can lean in a bit more.
I used to use a open ended end of a spanner to pop them off (to act as a "fork") , can't remember what size, I think 11mm is about right, but as its come off anyway simply twist / pull upwards to get the other end off.
I'm not sure (can't remember) if some of these have that big bush in the end of the main rod, I doubt that's failed as you'd still have some gears.
As above really, a look around the linkages will show the problem.
Andy.
