Radio
koppite34
Radio
Unread post by koppite34 »
I had to change my battery on my citroen xantia (99) the radio needs a code before i can hear it is citroen code the same for all or unique and where would i find this code? Looked in handbook nowt there any tips???
Mike
x 8287
Shame it's not a MK1 with the Blaupunkt. There are code calculators knocking around for those. Not sure about the MK2 Clarion. Someone will know...
A dealer will be able to furnish the code for a small fee and the VIN number, provided the radio is the same one as it started out with...
x 5648
It should be in the papers with the handbook.
lexi
x 134
Unread post by lexi »
People usually make a note somewhere in the handbook. Another long shot is that someone may have marked it on the side casing of radio.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5648
Mine was actually printed on one of the documents - possibly the initial receipt for the car.
brmartyn
Unread post by brmartyn »
I could be wrong but try 6662 that's what's in my handbook. It's worth at least one try :D
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
spider
x 77
Unread post by spider »
CitroJim wrote:Shame it's not a MK1 with the Blaupunkt. There are code calculators knocking around for those. Not sure about the MK2 Clarion. Someone will know...
I used to be able to do some of the Clarion ones in my head ;)
Andy.
andmcit
x 30
Unread post by andmcit »
When new Citroen Dealers wrote key/code and radio details on a plastic card
credit card sized so have a prod about the car (sunvisor?) and handbook pack.
There are sites that will give you the code based on the radio serial number
for around 20-25quid but it's cheaper buying a working one off ebay!!
Andrew
red_dwarfers
x 58
Unread post by red_dwarfers »
If you have a Clarion unit then you will not be able to calculate the code from any serial numbers (apart from quoting the cars VIN at the dealer). There is an 8pin surface mounted IC on the mainboard which contains the code, this can be read by making up a serial adapter cable and using a specific program. I have the details on the laptop which I'll dig out if you like. Very risky procedure as if you destroy the IC then you have a dead radio unless you can get hold of an identical preprogrammed IC, or a cheap blank one along with a burner and someone who can give you an image of the contents of the IC.
Kev
'19 C4 Cactus 130 Flair
x 1438
Unread post by xantia_v6 »
Contact the dealer who sold the car new. Some of them keep a local record of the number, and will give it to the owner for free.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
red_dwarfers wrote:If you have a Clarion unit then you will not be able to calculate the code from any serial numbers (apart from quoting the cars VIN at the dealer). There is an 8pin surface mounted IC on the mainboard which contains the code, this can be read by making up a serial adapter cable and using a specific program. I have the details on the laptop which I'll dig out if you like. Very risky procedure as if you destroy the IC then you have a dead radio unless you can get hold of an identical preprogrammed IC, or a cheap blank one along with a burner and someone who can give you an image of the contents of the IC.
I have this too.. the program runs in a DOS window...
I Have successfully removed 4 chips, read them and re fitted them ..
Its the only way unless you want to pay the dealer about 30 quid to look it up...
Paul
A very sad...
1994 XM 2.1 d auto
XMX
Re: Radio
Unread post by XMX »
koppite34 wrote:I had to change my battery on my citroen xantia (99) the radio needs a code before i can hear it is citroen code the same for all or unique and where would i find this code? Looked in handbook nowt there any tips???
Mike
Hi Mike, The best FREE way is to remove the unit from the the dash, get all the serial/model number etc off the label stuck on the case.
Then join THIS forum and then post a request with those details and hopefully someone gets back to you with the code (Usually within 24 hrs) as they did for me once !
I hope this maybe of help :D
