Clio mk1 1996 oasis - How to install rev counter
Joetcliooasis
I have bought a aftermarket rev counter and I am having trouble finding a signal cable. Where am I supposed to connect it to?
Renault Clio RL 1.2 Oasis
spider
- x 77
Without knowing much about this vehicle:
The typical place would be the coil lead (the low voltage one obviously!)
If you do not have the traditional coil and leads arrangement and have a coil pack, its going to be a bit more difficult. You may get a signal from one of the connectors on the coil pack, but I cannot be sure to be honest.
Bit late, but I wonder if it would be easier to simply fit an instrument panel from a tach equipped Clio model instead, I'd guess it would plug straight in (in most cases)
Andy.
