Can anyone tell me if there is any difference between the front and rear spheres, and also wheres the best place to buy them from?!
Gerry
Citroen Xantia 1998 2.1td rear suspension
- x 1238
citroenxm
- Fallen Hero
- x 70
Defenatly even AEP they are just as competative and good as GSF units..
Front to rears, yes there WILL be different pressures from front to back.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
XMX
As already stated front/rear are different, also the valve/damper sizes are diffenrent too !gerry1148 wrote:Can anyone tell me if there is any difference between the front and rear spheres, and also wheres the best place to buy them from?!
Gerry
Also as yours is a 2.1 TD I presume it will have the two extra Hydractive sphere too which may need replacing if there 'Tired' !
This LINK should help you to decipher what sphere volume/pressure/damper type you should be fitting as a replacement !
I hope it maybe of help
Xaccers
- x 185
2.1TD's weren't hydractive as standard, Dex for instance was a Desire (SX)
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
XMX
So that means that the Pdf/file link isn't 100% correct as there's no mention of a 2.1TD Non-Hydractive model in the listingXac wrote:2.1TD's weren't hydractive as standard, Dex for instance was a Desire (SX)
Well its the same list as featured on the 'Old-Guy's Xantia' site which 'GSF' is even titled in THAT Pdf/file
