Hi i have an s1 xantia activa, i was wondering if any has or would be able to tell me where to get hold of an anti roll jack for the o/s/r the citroen part number is 509004 if this helps.
thanks
ian
Im after a part
XantiaMan
- x 18
I assume this is the rear ram?
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
DickieG
- Monaco's youngest playboy
- x 33
andmcit
- x 30
XantiaMan
- x 18
Thanks, remembered.
2017 Fiesta ST
2017 Fiesta ST
- x 8397
bennett
Xaccers
- x 188
Can't justify???
You have an Activa man! That's justification enough
DIY sphere tool
DIY sphere tool
XantiaMan
- x 18
When the inevitable happens to mine, i'll get new ram. Its far more cost effective than buying another car which may need more work and cost the same as a new ram and then some. And of course, no modern 5 door hatchback comes close to the Activa experience.
2017 Fiesta ST
2017 Fiesta ST
bennett
- x 8397
admiral51
- (Donor 2026)
- x 391
- x 8397
addo
- Sara Watson's Stalker
- x 95
KevMayer
I called a Citroen dealer today and he quoted £403 incl vat for a rear ram part no. 509004.
I think I need a new one because my leak off pipe is dripping LHM but most importantly the top ball joint has a load of play in it. About 1/8" movement between the cup and ball, it looks like the lining of the ball joint (maybe ptfe ?) has worn away.
Cheers, Kev
