Differences in HP pumps
admiral51
(Donor 2026)
x 394
Unread post by admiral51 »
Have been following the thread in the Activa section about the weak pump but not wishing to dilute that particular topic decided to start a new one :)
How many variants are there for normal/non hydractive HP pumps(anti sink)
I have a 1.9d n/a im breaking but looking at its numerous feeds/outlets it looks different from the one in my 1.9TD in the areas that the pipes seem to go.It could be that the mounting position/angle is different that makes it seems totally different but all thoughts welcome :)
Colin
DickieG
Monaco's youngest playboy
x 38
Re: Differences in HP pumps
Unread post by DickieG »
admiral51 wrote:How many variants are there for normal/non hydractive HP pumps(anti sink)
According to Laser there are eight on S1's alone.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Xaccers
x 186
Unread post by Xaccers »
Image err, sorry Richard, did you say something?
DIY sphere tool
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Those two should be completely compatible!
Has the 98 LX TD Got Air Con?? If so the HP Pump will be up top above the altinator..
I guess the 96 D wont have, but it should have anti sink, so you should find that the two pumps WILL inter change.. the main difference I learnt is the VSX and V6 Pumps differ from the TD Pumps... Petrol engines use a different size PULLY, But my guess is a Petrol LX Pump would do the job, but a longer belt would possibly be needed to go round the larger pully..
So in summery, I think its only VSX/Hydractive Pumps that should bot be used on LX / SX systems..
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 38
citroenxm wrote:So in summery, I think its only VSX/Hydractive Pumps that should bot be used on LX / SX systems..
Where did you get that from Paul? Looking on Laser there's no mention of a Hydractive pump being different unless the car is a V6 :?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
citroenxm
Fallen Hero
x 70
I had this discussion the other day elsewere... the unless Im getting mixed up and confusing the VSX is NOT the same as the V6 Pump..
So a VSX hydraulic pump can be put on a Non Hydractive LX/SX car??
But a V6 cannot be put on a LX/SX/VSX car?
Paul
A very sad...
1994 XM 2.1 d auto
admiral51
(Donor 2026)
x 394
Just to clarify the situation here guys :)
Im looking at the feaseability of putting the pump from my 1.9d n/a onto my 1.9TD both have A/C and are anti sink.
It just looks to me that the input/output on the pumps are different but that could just be the way the pump body is aligned/rotated on its mounting bracket.
The reason for swapping them is that i know the pump on the 1.9d n/a was serviced/reconditioned before i bought the car.Best i take some pics of the engine bay of both and post up for opinions :)
Both cars are S1 cars Richard
And yes Richard both compliment each other very nicely in your new avatar 8)
Colin
DickieG
x 38
citroenxm wrote:I had this discussion the other day elsewere... the unless Im getting mixed up and confusing the VSX is NOT the same as the V6 Pump..
Paul
According to Laser there are seven different anti-sink pump's on a S1 dependent upon engine and whether A/C is fitted, so if I'm reading Laser correctly LX/SX/VSX pumps will be interchangeable if the donor/recipient cars have the same engine and are both fitted with/without A/C.
The V6 pump is in addition to the seven and unique to that engine/not compatible with other models.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DickieG
x 38
Colin, do you have the RP numbers available for both cars?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Pleiades
Unread post by Pleiades »
Just to put a little light on. :idea:
There are lots of different Xantia style pumps.
Basic types are,
6 cylinder petrol
6 cylinder diesel
6 + 2 cylinder petrol
6 + 2 cylinder diesel
6 + 2 cylinder XM 2.1 TD
6 + 2 cylinder XM 2.5 TD
6 + 2 cylinder XM 2.0 petrol turbo (also fits activa)
6 + 2 cylinder Xantia V6 (only fits the V6)
6 + 2 cylinder HDI
In with these pumps there are some slight variants, this can be pulley size, angle of the pipes or distance from the pump to the back of the pulley.
Most pumps are the same inside. In other words, if it looks the same and the belt runs in line, then it will work.
The 6 cylinder pump runs with the old fashioned BX system, ie the car has a Flow distributor valve to control the pressure and flow to the steering pinion valve (150-)
The 6 + 2 pump has the 2 pistons to pressurise the suspension and braking system and the 6 piston side has it's own internal regulator that controls the 150- pressure to the steering at full flow. (no flow valve needed)
The big main difference is the Xantia V6 pump, this pump looks like a standard pump, but it has no internal regulator for the steering. The regulator sor the steering is up and attached to the N/S inner wing. Fit this pump to a standard Xantia and you will over pressurise the pinion and blow fluid out all over.
The Xantia V6 pump is easy to identify, as it has the pulley held onto a hub with 4 x bolts.
Regards
Martin.
citroenxm
Fallen Hero
x 70
Just a quick point,
NEVER Seen an XM 2.1 with a 6+2 pump..
Did they come in quite late on them?
Paul
A very sad...
1994 XM 2.1 d auto
admiral51
(Donor 2026)
x 394
Thanks Martin makes things a little clearer :)
Richard i do have both RP numbers(well access to them) and VIN numbers so will post them up tomorrow along with some pics
Thanks for all your input :D
Colin
Pleiades
Paul.
It was the last of the XM's that used the Xantia system, by then they were only using the 2.0 petrol turbo and the 2.1 and 2.5 turbo diesels.
We allways have to do a double check when someone is ordering a pump for a late type XM as it is easy to get spomethging wrong.
Regards
Martin.
lexi
x 134
Unread post by lexi »
The longer post of Martins is Sticky material.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
admiral51
(Donor 2026)
x 394
Cant post any pics cos i forgot to take my camera with me to work #-o
I do however have the following
P516 CRA 1.9D n/a with A/C VF7**************[VIN obfuscated, can be read by forum staff] RP 7163 CJ
R620 OGM 1.9TD with A/C VF7**************[VIN obfuscated, can be read by forum staff] RP 7499 CJ
Hope this helps you gents to help me :wink: :)
Cheers
Colin
