Mine is leaking slightly, enough to upset the pump at startup after the car has sat all night
Cheers, Colin.P
Slightly off topic (as I'm not the one who's got this problem) , I wanted to do that to mine but as its a TD205, its not "that" easy given the hose locations for the oil cooler etc, I looked into it, they never fitted that filter design to the turbo 205's, only the NA ones (which did not have an oil cooler) , its just about possible but I need to mix/match a lot of hoses. I've got a topic open about my "home made" fuel heater although I've not had chance to fit it yet due to the snow etc.CitroJim wrote:Personally, if it were I, I'd go to the scrappy and get hold of the later XUD filter mounted on the thermostat housing (The "Gasholder" shaped one). You'll need the thermostat housing and priming bulb too but you do then get the distinct advantage of a fuel heater underneath the filter...
