xsara over heating
Road_Hog
xsara over heating
The wife's Xsara 1.4 2002 has overheated on the way to work this morning (engine warning light has come on). I know there is plenty of water in the rad/expansion bottle as I topped it up with anti-freeze earlier this week. So what are the most likely problems and watch is the check list to try to eliminate them. Is it most likely to be a faulty thermostat and if so any pointers as to where it is located?
- x 1459
Road_Hog
Cheers for that, it appears that you were right, the radiator seems to have unfrozen now and have put some more anti-freeze in, so hopefully that will be the end of the problem.xantia_v6 wrote:Depending on the concentration of anti-freeze in the radiator, it could be that the water in the radiator froze, stopping circulation and allowing the engine to overheat.
Run the engine at idle for a while and see if the radiator gets hot.
