Just got a berlingo van to day and need help!!!!!
hi
got my 98 berlingo van today and i have got no heaters checked all fuses any one got any ideas??
paul
paul
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Check coolant flow to the Matrix, under the bonnet were the water pipes go int to the matrix there should be a bleed valve - same as a tyre valve cap.. with the engine running, take the cap off and see if theres any water flowing from it!
EVEN at idle there SHOULD be a good flow from it...
If not, then either the Matrix is blocked, or your cooling system has had a hard time with NO ANTI FREEZE, which CAN affect the head gasket..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Ah right.... SORRY...
Sounds like the Resistor pack has packed up, which controls the 4 speeds, unfortunally, I DO NOT know were its located on the Van.. only in Xantias.
Its useually mounted so the resisters are IN THE Airflow, to help keep them cool.. Have a look at the blower Air Ducting under the dash, possibly hidden by some trim under the dash in the passenger footwell..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Yes loose connection, check the plug thats connected to the bottom of the blower motor, Ive known these (On Xantias) to melt the terminal boot through a loose connection and getting warm..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
How far up the guage does the needle go?? If the thermostat is sticking OPEN it wouldn't even move off the guage in this cold weather....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
