still no ns suspension
acr car
hi can anyone help still have no n/s front suspension after relaceing sink valve seal on n/s front of my Xantia esttate rear working all ok going up and down o/s front in normall position but not going up or down with back when placed in full up or low have no oil flow out of lhm pipe to top of ns spher also can anyone suggest best place to buy seal for pipe as unable to get back in now seal moved removed sink valve again to check all pipes look ok seals look good
- x 1240
acr car
no oil comeing out of ns spher pipe with car running ok till leaking sink valve car drove fine but not surer if front was going up to full position.os also not moveing from normall is it possible front low on pressuer and os staying normall as not been leaking on that side ns will not work as lost oil
- x 1240
- x 94
may be you have pinched a piece of the seal which has gone into the system causeing a blockage, its a bit risky disconecting a main feed pipe on a live system, as there is about 2,600psi coming through those pipes,
year ago we had a newly qualifyed F**D mechanic come for a job at a citroen service agents i used to work for,
my boss took him on and the first job he had was a clutch on a GS, this job involves disconectting the main presure feed to the regulator, on startting up after re/assembling the reg sphere exploded,
my bosses son fitted a good S/H sphere for that one to pop/split wide open as well,
replaced the comnplete regulator this sorted it,
next my bosses son striped the old regulater and found a tinny piece of the pipe seal inside the regulator,
no one had though to tell him about the pipe seals,
regards malcolm
regards malcolm
acr car
Xaccers
- x 188
Use a small mirror and torch to check the state of the hole to see if the seal is in the way.
If you need to remove it, I find a small flat screwdriver can be used to gently pull the seal out, otherwise a metal pick can do it (you know like the bent sharp things dentists use).
DIY sphere tool
DIY sphere tool
acr car
no ns front suspension
replaced sink valve with second hand from scrap yard now front suspension working again sitting up high now than before leak on front need to adjust on ramp thanks all for help
citroenxm
- Fallen Hero
- x 70
Well thats an interesting discivery, the anti sink valves, being completely mechanical dont useuall cause a problem..
A piece of the pipe seal could very well have got caught in there, becuase when you remove pipes you get "Hairs" on the ends of the seals and if not cut off can be pushed into the area the pipe needs to go!
Well done for getting her fixed up!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
